    Dec 06, 2011 @ 10:07
    Anthony Candaele
    problem creating custom404 pages for a multilingual website
    I having problems creating custom404 pages for a multilingual website.
    My multilingual websites are built in Umbraco 4.7.1 and run on IIS 7.5
    In the umbracoSettings.config file is configured like this:
    <errors>
                <!-- the id of the page that should be shown if the page is not found -->
                <error404>
                <errorPage culture="nl-BE">1176</errorPage>
                <errorPage culture="fr-BE">1177</errorPage>
                </error404>
                <!--<error404>1</error404>-->
            </errors>
    But if I enter a fictituous url, instead of my custom 404 pages, I still get the default IIS error 404 page.
    Anyone an idea how I can solve this?
    Thanks for your help,
    Anthony
  • Duncan McDougall 35 posts 62 karma points
    Dec 06, 2011 @ 10:24
    Duncan McDougall
    I found this on SO. Looks like a similar issue. http://stackoverflow.com/questions/6929304/add-custom-404-pages-in-umbraco-4-7
    This guy built himself a custom handler which he provides the code for.
    From the comments Sebastiaan does write that this will be fixed in the next release.
    Dec 06, 2011 @ 10:38
    Anthony Candaele
    Hi Duncan,
    Thanks for the advice. I also saw this post, maybe I should try this solution.
    I already tried using the Multisite Page Not Found handler in uComponents, but this isn't working either.
    greetings,
    Anthony
    Dec 06, 2011 @ 10:46
    Anthony Candaele
    Hi Duncan,
    In that post on SO, Sebastiaan replies that the <errorPage> node should be changed to <error404> so I changed my umbracoSettings.config to:
    <errors>
                <error404 culture="nl-BE">1176</error404>
                <error404 culture="fr-BE">1177</error404>
            </errors>
    but it still doesn't work .... sigh
    Anthony
    Dec 06, 2011 @ 15:45
    Duncan McDougall
    Hi Anthony,
    Could be wrong but I read that as he needed to change the errorPage to error404 in his custom handler for naming convetioning. The custom code is still what he used. If you give it a go let me know. Could be working on a multilingual next week.
    Duncan
    Dec 06, 2011 @ 16:42
    Anthony Candaele
    Hi Duncan,
    I would love to try this custom handler class, but I'm not that familiar with custom handlers. Where exactly should I put this code in my webfolder, or do I need to create a lokal VS Solution, then compile the class and put in the /bin folder of my live website?
    Thanks for the advice,
    Anthony
    Dec 08, 2011 @ 00:31
    Duncan McDougall
    Anthony,
    Sorry for the delay. Everything you should need can be found in these two wiki pages.
    http://our.umbraco.org/wiki/how-tos/how-to-implement-your-own-404-handler
    http://our.umbraco.org/wiki/reference/files-and-folders/files-in-the-config-folder/404handlersconfig
    Short answer. You can put it anywhere in your own solution as long as you have your dll in the /bin folder and you reference it in 404handlers.config
    e.g.
    <notFoundassembly="MyLibrary"namespace="MyLibrary.Handlers"type="MyNotFoundHandler"/>
    It's been a few months since I've done this myself but it sound about right.
    Dec 08, 2011 @ 15:24
    Anthony Candaele
    Hi Duncan,
    Thanks for the information.
    Still no white smoke I'm afraid.
    I created a new web application project (Custom404Handler) in VS 2010, created a class (Custom404) and copied the code for a custom 404 handler from Stack Overflow.
    I referenced the necessary dll (interfaces.dll, businesslogic.dll, umbraco.dll) and compiled the class without any issues.
    Then I put the compiled custom404handler.dll in the /bin folder of my live site.
    I put this line in my 404handlers.config
    and I configured my umbracoSettings.config like this:
     <errors>
            </errors>
    but alas, I'm still getting the default IIS 404 error page.
    greetings,
    Anthony
    Dec 08, 2011 @ 15:52
    Duncan McDougall
    If you copied the code directly you should try <errorPage culture... instead of <error404>. I think Sebastiaans note was to the guy who wrote the code to change it for consistencies sake.
    Dec 08, 2011 @ 18:03
    Anthony Candaele
    yes!! it works. I followed your last suggestion, and I also changed this line in the 404handlers.config file:
     <notFound assembly="Projectlibrary" type="Custom404Handler"/>
    to
     <notFound assembly="Custom404Handler" type="Custom404"/>
    following this format:
     <notFound assembly="name-of-dll" type="name--of-custom404-class"/>
    Thanks for hanging on Duncan, and I hope this solution will work for your multilangual project too.
    greetings,
    Anthony
