  • Chris Koiak 700 posts 2626 karma points
    Dec 06, 2011 @ 10:30
    Chris Koiak
    RichTextEditor (TinyMCE) Nested Lists Markup
    When I nest unordered lists via the RichTextEditor then nested UL is wrapped <li style="list-style: none;"/>
    Does anyone where you can change/control this?
    I'd prefer the markup to either use a class name on the surrounding LI or (ideally) include the nested UL in the last valid LI.
    Generated markup (after you hit save)
    <ul>
    <li>Item 1</li>
    <li style="list-style: none;">
    <ul>
    <li>Sub Item 1</li>
    </ul>
    </li>
    <li>Item 2</li>
    </ul>
    Dec 06, 2011 @ 22:39
    Hi Chris
    I'm not sure where to actually change this odd behaviour but as a workaround I suppose you could write something like
    html .yourrtecontentcontainer li{display:block} or use jquery to remove the style attribute? I know it's not ideal but perhaps it could do as a workaround?
    Dec 07, 2011 @ 09:23
    Chris Koiak
    Thanks for the response Jan. The css approach won't work as the li is already block and I'd use jquery as a last resort for this.
    The main issue is that the parent li has a background image as a bullet, therefore I end up with a, seemingly, additional bullet.
    Any other thoguhts?
  • Euan Rae 105 posts 135 karma points
    Dec 07, 2011 @ 11:28
    Euan Rae
    2
    You could try going into the tinyMce.config file and in the '<validElements>' section, and try update '-li[class|style]', to be '-li[class]'.  Not 100% sure if this will work though.
    Dec 07, 2011 @ 11:32
    Chris Koiak
    Nice idea Euan, definately stops the inline styles. However doesn't stop the un-neccessary LI tag or give me control via CSS 2
    Dec 07, 2011 @ 12:33
    Chris Koiak
    2
    I've found the solution! You need to install and enable the 'lists' plugin.
    • Get the source for TinyMCE and move '\tinymce\jscripts\tiny_mce\plugins\lists' folder to '\umbraco_client\tinymce3\plugins\lists'
    • Add the following line to the 'plugins' section in 'config\tinyMceConfig.config'
    <plugin loadOnFrontend="true">lists</plugin>
    Thanks to everyone for their input.
