Anyone any ideas / techniques or packages that they are aware of so that I can move a text datatype from a parent doc type to a child doc type without losing any data?
One idea i had was to export the page name and the field data into sql server. Move the datatype which will lose data then import using cmsimport.
Create the datatype on the child doc type (probably using a different alias), and perform sql statements to do the data move. Both datatypes will have their own controlId (guid), so it should be possible to move data between those records in cmsPropertyData. Just make sure to get the latest version of each of the cmsPropertyData records for each of the documents you already have.
That would be possible(and I should promote that ;-) )But I think it would be easier if you the property on the child datatype as well and then create a Dashboard control that takes all documents of the child document type and copies the date from its parent document. When finished you remove the datatype from the parent document type and the data is moved.
Move datatype from parent to child
Regards
Ismail
Ouch, this one is tough... I'd do the following:
Oh, backup first!
/Dirk
Hi Ismael,
Richard
