  • jigar 170 posts 233 karma points
    Jul 02, 2009 @ 16:23
    jigar
    How to use Canvas?
    Hello All,
    I am using umbraco v 4.0.1 (Assembly version: 1.0.3373.718) of umbraco. i am happy using umbraco.
    i want to enable inline editing using canvas, how can i do that?
    when i right click on any node and click on edit at that time i go the following message.
    Umbraco Canvas requires an ASP.Net form to function properly. Live editing has been turned off.
    please help me in solving this.
    Regards
    Jigar
  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Jul 02, 2009 @ 16:29
    Warren Buckley
    2
    Hi Jigar,
    You need to add a form tag around the entire page. Which if you have any child nested form tags it will break.
    Add the form tag with runat="server"
    <form runat="server">
    <div>Your entire page XHTML</div>
    </form>
    Jul 02, 2009 @ 16:47
    jigar
    Thanks A lot mate.. i love this community...
    Jul 02, 2009 @ 16:55
    Dirk De Grave
    Hi jigar,
    Don't forget to mark the post as the solution to your problem! If you do, we'll love you as well!
    /Dirk
    Jul 07, 2009 @ 15:56
    jigar
    Sure I will...
    Jul 07, 2009 @ 16:21
    Dirk De Grave
    Do you see a green check mark somewhere? It's that button you'll have to click to mark Warren's post as solution!
    /Dirk
    Jul 07, 2009 @ 16:37
    jigar
    Done... Was that ranking cont somewhere? just curios to know ..
            Give answer and win points, take away your IPOD ;)  just kidding mate..
