How to run an umbraco project from existing files in WebMatrix?
I had someone develop an umbraco site for me using WebMatrix. They sent the code files over to me. I tried the "site from folder" option in WebMatrix. But when I run it, it shows a server error. Then i created an umbraco project from the webgallery and copied over the files, got the same error
is there a fault in the code? or is there a more appropriate way to run it?
Exception Details: System.ArgumentNullException: Value cannot be null. Parameter name: value
Source Error:
Sorry if the question seems silly, i'm a noob.
thanks.
Have you checked the connection strings in the web.config? It sounds as though you could be having problems establishing a connection to the database.
coud be.. here's more detail on the error I get:
Source Error:
