i have a problem and found not the solution. In a usercontrol is a further usercontrol integrated.In the parent-usercontrol is a object. When i access in the child-usercontrol of the object in the parent-usercontrol, i become a error-message. Here is the code as example.
Listing.ascx.cs
public partial class Listing : System.Web.UI.UserControl { .... private ListingResult _listingResult; public SearchResult searchResult { get { return _searchResult; } } .... public Listing() { _searchResult = new SearchResult(); } ....
_searchResult = _searchResult.getSearchResultsFromQiuckSearch(Request["quickSearchString"]); .... if (_searchResult != null) { //a control display on the website for me Debugger.ausgabe += "Listing Zeile:79<br>searchResult.categorys.Count: " + searchResult.categorys.Count + "<br>"; //intergrate the child-control _listingResult = (ListingResult)LoadControl("ListingResult.ascx"); plh_listingMainContent.Controls.Add(_listingResult); } .... //integrated the control display this.lbl_1.Text = "<hr>anfang<hr>" + Debugger.ausgabe + "<hr>ende<hr>"; }
private ListingResult.ascx.cs
public partial class ListingResult : System.Web.UI.UserControl { private Listing _parent; private SearchResult _searchResult; ... public ListingResult () { _parent = new Listing(); //to integrate the parent-usercontrol Listing _parent = (Listing)this.Parent; //my control display Debugger.ausgabe += "ListingResult Konstrutor<br>Listing.searchResult.categorys.Count: " + _parent.searchResult.categorys.Count + "<br>";
I create the usercontrols in visual studio 10 on a local machine, to compile the code and copy the .ddl in the bin directory from umbraco on a webserver. When i only activate the control-display (Debugger.ausgabe) in Listing, code to compile, is okay, copy to the webserver and refresh the website, i see the display the category-list in searchResult have 5 entrys.
When i activate the control-display (Debugger.ausgabe) in Listing and in ListingResult, code to compile, is okay, copy to the webserver, i become a error NullReferenceException: Object reference not set to an instance of an object.
I not understand, the object is in the parent-usercontrol exist.
Can you help me?
Sorry, my english is not the best, i hope the problem is understandable.
_listingResult = (ListingResult)LoadControl("ListingResult.ascx"); /* 16.12.2011 HKN * Erstellung der Ergbnisanzeige im Kindcontrol (ListingResult) durch diesen Funktionsaufruf * erst danach an dieses Control anfügen */
//started the function in the child-control _listingResult.createResultList(_searchResult); plh_listingMainContent.Controls.Add(_listingResult);
object not found in a parent usercontrol
hi,
Listing.ascx.cs
public Listing()
Can you help me?
cu
harald
I have a other solution found.
Listing.ascx.cs
/* 16.12.2011 HKN
cu
harald
