Setting the preset width for using images larger than 500 in RTE
Hi!
Recently a customer wanted to insert a image with a width larger than 500 pixels in a RTE. The RTE then proceeded to shrink down the image to a default width of 500 pixels. Is there a way to turn this off? Is there a way to change the preset width to something else?
Jesper, thanks for helpig remind people of that, I am going to try to be more active again starting today, and I came to answer this thread to see that Peter already beat me to the punch, but it was not marked as solved -- plus one for both of you!
Hi!
Hi Pierre,
If you go to the developer-section, then Datatypes and then Rich text, you can specify the maximum width of the images in the RTE.
You can also change the default width and height of the RTE itself when editing a page.
HTH,
PeterD
Thanks Peter, it seems to work!
@Pierre, please remember to mark Peters answer as a solution to your question (helps others to find it and rewards Peter). Click the green sign.
/Jesper
