This code is meant to be used in the Umbraco back-office, via a custom datatype, dashboard control, or other Umbraco page. Based on your other thread I'm assuming you meant to use this in the front-end, in which case you're on the right track with fancybox/colorbox. If you're interested in using the backend and need more help, let me know!
I am creating a custom control.after clicking link in the custom control and i am openining modal window.Now i want to load an image into this window.that image i want to take from upload control in my document instead of media picker tree .how to do it in umbraco 4.7.1.1?
How to create a custom backoffice popup
I am looking for a way to add a new popup near the backoffice About popup with the same style but with different content..
I can see the About popup is loaded using UmbClientMgr.appActions().launchAbout();"
but is there anyway to create a custom popup using the same styles?
You can use the openModalWindow function to open a "modal" which should be what you're looking for. Ex:
<a href="javascript:UmbClientMgr.openModalWindow('page url', 'window title', true, 500, 400,0,0,'', callbackFunction();">Open</a>-Tom
Thanks Tom.. Thats exactly what I was looking for :)
Hi Tom,
How exactly is the "modal" example executed?
Could you please provide "for dummies" instructions? Where to place code, what to change, etc.?
New to Umbraco. Thanks in advance.
Hi Jason,
-Tom
hi tom fulton,
Hi Siva,
If I'm understanding - you have a custom page (in a modal) and you want to pull in the value of a document's upload field to display as an image?
You'd probably want to use the Document API to get the document and the upload property, something like:
Hope that helps, Tom
