  • fatnjazzy 12 posts 31 karma points
    Jan 06, 2012 @ 16:51
    fatnjazzy
    Umbraco 5 - Can't generate URL for a content node
    I am getting this error when adding a content node:
    A URL could not be generated for this node because the branch it is contained in requires that a hostname is assigned.
    This is the Content Type settings:
    Jan 06, 2012 @ 17:17
    Jeroen Breuer
    Please report v5 issues here: http://issues.umbraco.org.
    Jeroen
    Jan 06, 2012 @ 17:52
    fatnjazzy
    Why do I have to create host name for each content node?
  • Tom Madden 253 posts 455 karma points MVP 4x c-trib
    Jan 07, 2012 @ 11:36
    Tom Madden
    This is the message I got when I had created document types called 'home' and 'content', once I changed them (and I think it was the 'home' one that was the problem), then it worked without having to enter a hostname (which doesn't solve the problem anyway).
    See the v5 issue here: http://issues.umbraco.org/issue/U5-4
    HTH
    Tom
