It would require a bit of research to find out how to embed the tags on the page so that cumulus tag cloud could read it, but in theory, yes this should be perfectly doable! There's some info on using tag cloud with other systems here if that helps: http://www.roytanck.com/2008/05/19/how-to-repurpose-my-tag-cloud-flash-movie/
Tag cloud (Flash-based Cumulus) in Umbraco
I like the Flash plug-in that generates the Cumulus tag cloud.
Examples:
http://www.roytanck.com/tag-cloud
http://www.dnn360.net/Default.aspx?tabid=1744
Is it possible to use such a plug-in with Umbraco Runway Blog?
Leszek
Hiya,
