  • Jeff 21 posts 42 karma points
    Jan 07, 2012 @ 01:52
    Jeff
    Is there a way to Crop Images with different shapes?
    I would like to be able to crop images to conform to circles. Is this possible? Are there any extensions that will allow me to do such a task?
    Any help much appreciated.
    Thanks!
    Jan 07, 2012 @ 10:15
    Hi Jeff
    I don't think any of the available croppers out there allow you to crop anything else than squares. But it's an inspiring thought that the package creators perhaps can consider an option to include? :)
    But I'm thinking that you perhaps should check out the pixlr pakcage, which makes it possible to edit images in pixlr where I belive you should be able to make circle selection and save the result back to the media section in Umbraco.
    You should perhaps also check out DAMP, which also has pixlr integration and a bunch of other cool features. Maybe this really is the way to go.
    Hope this helps.
    /Jn
