  • Jeff 21 posts 42 karma points
    Jan 09, 2012 @ 17:28
    Jeff
    Ideal way to create galleries?
    A. Create a container for each media image. And then you can let the gallery page have those containers as subnodes as shown in the following video:
    http://www.youtube.com/watch?v=_J7TiN0QiAY&feature=related
    B. Have the gallery page have a folder of images as the subnode
  • Funka! 398 posts 661 karma points
    Jan 10, 2012 @ 02:19
    Funka!
    I saw Niels' video showing how to create a gallery via some new document types with the Upload data type a while ago, too, but we found the advice presented here { http://www.diplo.co.uk/blog/2011/4/8/creating-a-simple-image-gallery-in-umbraco.aspx } to be much nicer for our purposes.
    In a nutshell, and what this article linked above will suggest, (is that what you meant by option "B"??)  is that we prefer to manage our slideshows/galleries as simply a folder of images managed in the Media section of the back office, not as individual nodes managed in the Content section.  We then can create a single document type called Photo Gallery Page which has a single Media Picker property on it. We pick the folder containing the images and then using some razor can easily loop through its contents on the display side. (The article I linked does this in XSLT but is just as easy to do in Razor.) Using ImageGen to automatically generate the thumbnails is a wonderful bonus & timesaver!
    I think the concept in Niels' video and what I'm discussing is practically the same: one way you just manage a series of content nodes, the other way as just managing a media folder filled with images. Although it is possible with our suggestion to easily add a few photos to an existing gallery using the Desktop Media Uploader, without ever having to visit the back office UI!
    Best of luck!
    Jan 10, 2012 @ 22:51
    Jeff
    Thank you so much, Funka!. You answered my question perfectly, and it's just as I had thought. It does seem to make things much more easy for the client that way.
