  • Adrian Alexa 50 posts 100 karma points
    Jan 11, 2012 @ 14:40
    Adrian Alexa
    Usercontrolers does not work when insert form tag
    I found the same issue on this post( http://our.umbraco.org/forum/using/ui-questions/19391-Usercontrol-not-working-in-umbraco?p=0#comment102880 )
    I will come with details. I create a macro which contains a form 2 hidden fields and a button.
    It renders content on frontend when controller is without form tag. When I insert it it shows me on content tab: No macro content available for wysiwyg editing.
    Here is CODE
    <%@ Control Language="C#" AutoEventWireup="true" CodeBehind="SignUpButton.ascx.cs" Inherits="HoteloProModules.SignUpButton.SignUpButton" %>
    <div class="div_center">
        <form name="formSignUpp" id="formSignUp" runat="server" action="" method="post">
            <div class="btn_class_a">
                <div class="btn_left"></div>
                <asp:HiddenField ID="hidMaxNrOfRooms" Value=""  runat="server"/>
                <asp:HiddenField ID="hidAccountType" Value="" runat="server"/>
                <asp:Button CssClass="btn_center" Text="SIGN TEMP" runat="server" ID="btnSignUp"/>
                <div class="btn_right"></div>
        </form>
    and code behind CODE
        public partial class SignUpButton : System.Web.UI.UserControl
            private Int16 MaxNrOfRooms, AccountType;
            /// <summary>
            /// 5, 25, 50
            /// </summary>
            public Int16 _MaxNrOfRooms
                get { return MaxNrOfRooms; }
                set { MaxNrOfRooms = value; }
            /// <summary>
            /// 1 2 or 3
            /// </summary>
            public Int16 _AccountType
                get { return AccountType; }
                set { AccountType = value; }
            protected void Page_Load(object sender, EventArgs e)
                btnSignUp.Text= umbraco.library.GetDictionaryItem("SignUp").ToUpper();
                hidMaxNrOfRooms.Value = _MaxNrOfRooms.ToString();
                hidAccountType.Value = _AccountType.ToString();
                formSignUp.Action = "https://" + HoteloProGenerals.WebAppRootNoScheme + "Register.aspx";
    The reason why I need there a form is because I want a button that when is pressed to send/redirect/post to an address transfering values.
  • Michael Latouche 504 posts 819 karma points MVP 5x c-trib
    Jan 11, 2012 @ 15:38
    Michael Latouche
    Hi Adrian,
    The problem is that your template, if it is a classic asp.net masterpage, probably also contains a global "form" tag. What you could do is remove the form tag from your control, but then change the action of your main form when you click on your formSignUp button.
    So, instead of server-side assigning the form action do it client-side, something like this:
    <input type="submit" id="btnSignUp" onclick="SetSignupAction();">
    and then define a javascript method:
    function SetSignupAction()
    document.forms[0].action = "https://<%HoteloProGenerals.WebAppRootNoScheme%>Register.aspx";
    Or any jquery equivalent...
    Not tested so no error-proff guarantee ;-)
    Hope this helps.
    Michael.
    Jan 11, 2012 @ 15:41
    Michael Latouche
    Sorry, I did not pay attention you were using asp:Net button, so no <input type="submit" .../> for you but
    <asp:Button CssClass="btn_center" OnClientClick="SetSignupAction();" Text="SIGN TEMP" runat="server" ID="btnSignUp" />
    Michael.
    Jan 12, 2012 @ 10:05
    Adrian Alexa
    Hi Michael,
    afterall I found a cause why it was like that.
    The macro was inserting in a form that has runat="server". So you can not have one form within other with runat=server.
    The solution: instead of using asp.net cotrollers I used classic html form tags. And it works.
    Jan 12, 2012 @ 10:10
    Michael Latouche
    Hi Adrian,
    It's great you found it!
    Michael.
    Jan 12, 2012 @ 10:12
    Adrian Alexa
    oh yeah..after some good hours...now I am struggling with language :D (one domain and multiple langs)
