Hi I tried to add youtube command in tinymce.config but when i run the datatype i get this error
I tried to follow the following link:
There is also however a spellchecher at number 75 as priority
http://our.umbraco.org/wiki/how-tos/customizing-the-wysiwyg-rich-text-editor-%28tinymce%29/add-youtube-button-to-tinymce
any solution would be useful
i find that wiki document useless
Hi Max
What happens if you change the priority to something else like 76?
Did you also remember to recycle the app pool? Sometimes this is needed in order to make sure that the changes take effect.
i did that and recycled thing it worked fine
Thank you JAN cheers
That information should probably be added to the wiki then - I'll try to look into it.
Happy to hear you got it solved.
Remember to mark the topic as solved.
Jan
rich text editor Datatype error
Item has already been added. Key in dictionary: '75' Key being added: '75'
Hi Max
Hi Max
Jan
