  • Lee 95 posts 115 karma points
    Jan 12, 2012 @ 11:16
    Lee
    Adding span tags
    I have created stylesheets in umbraco, but is there a way I can add a span tag (from the drop down menu) the would need a class. ie.
    <h1>This is a heading 1 with a span tag included</h1
    Would be:
    <h1>This is a heading 1 with a <span>span tag</span> included</h1
    without the need of doing it manually. I know it works if you apply a different class to the tag.
    Is this possible?
    Cheers
  • Rodion Novoselov 694 posts 859 karma points
    Jan 16, 2012 @ 19:06
    Rodion Novoselov
    Hi. Just add a fake empty class to the RTE associated stylesheet. When you select some string and select that from the drop-down list a <span> tag will be applied to the selected text.
