Dynamic loading of partials from controller called by JQuery in Umbraco 5
I am in the process of moving an Intranet from Umbraco 4.x to Umbraco 5 - MVC 3.
My old solution is built on a whole bunch of Jquery and Ajax loading. All the data loading in the old solution is done through .ashx handlers that are beeing called by Jquery, to return JSON objects.
I have proted all my old handlers to controllers, and are down to one problematic devil :-D
In the old solution I have a handler, that are able to take the name/path of a usercontrol as input, and then load this control, and return the HTML, to be injected into a Jquery popup window.
The code for rendering looks like this:
private static UserControl LoadControl(string UserControlPath, params object[] constructorParameters)
Page pageHolder = new Page();
List<Type> constParamTypes = new List<Type>();
foreach (object constParam in constructorParameters)
constParamTypes.Add(constParam.GetType());
UserControl ctl = pageHolder.LoadControl(UserControlPath) as UserControl;
// Find the relevant constructor
ConstructorInfo constructor = ctl.GetType().BaseType.GetConstructor(constParamTypes.ToArray());
//And then call the relevant constructor
if (constructor == null)
throw new MemberAccessException("The requested constructor was not found on : " + ctl.GetType().BaseType.ToString());
else
constructor.Invoke(ctl, constructorParameters);
// Finally return the fully initialized UC
return ctl;
It work very well in Umbraco 4.x.
In Umbraco 5 I am trying to do something similar with Partial Views.....BUT GRRRRRRR - what ever I do I get an unhandled Exception like this:
I am trying to do the following:
public PartialViewResult AddCompany()
string ReturnContent = RenderPartialViewToString("AddCompany", null);
return PartialView(ReturnContent);
protected string RenderPartialViewToString(string viewName, object model)
if (string.IsNullOrEmpty(viewName))
viewName = ControllerContext.RouteData.GetRequiredString("action");
ViewData.Model = model;
using (StringWriter sw = new StringWriter())
ViewEngineResult viewResult = ViewEngines.Engines.FindPartialView(ControllerContext, viewName);
ViewContext viewContext = new ViewContext(ControllerContext, viewResult.View, ViewData, TempData, sw);
viewResult.View.Render(viewContext, sw);
return sw.GetStringBuilder().ToString();
AddCompany is just a static test partial view.
Can someone please enlighten me on this issue???
I am kind of stuck here.
/Christian
Forgot to mention - the code is in a custom assembly, and the views are palced in a folder corresponding with the name of the Controller.
