OK, looking at the source, it looks like the inbuilt handler will never match when not using multiple domains anyway (just subfolders as multiple root nodes), as the culture isn't set until after this point.
I'll therefore use the uComponents handler, so need to work out why that isn't working...
Localised 404 pages in 4.7.1.1
I understand some stuff was changed/fixed in 4.7.1.1 relating to localised error404 pages, but this still isn't working for me?
I have in umbracoSettings.config
but all locale sites (which otherwise work fine) hit node 1139. Using umbDebugShowTrace shows;
NotFoundHandler 'umbraco.handle404 found node matching de/foobar with id: 1139and only later on;
Culture changed to en-USOn valid existing pages, the culture is correctly de-DE for example.
I've also tried using uComponents MultiSitePageNotFoundHandler, but that's not working for me either, just
Trying NotFoundHandler 'uComponents.Core.NotFoundHandlers.MultiSitePageNotFoundHandler'...and nothing else relevant
There are lots of topics relating to this type of problem, but I can't seem to find a definitive working solution!
Phil
Phil
