I have a question about some problemens with multiple sites and the search results in Google. I use the following Umbraco structure:
Site1.nl
- Page 1
-- SubPage1
-- SubPage 2
etc.
Site2.nl
- Page 1
-- SubPage 1
-- SubPage 2
-- SubPage 3
This works fine and Google will find the content from Site1.nl en Site2.nl. So content form SubPage 1 in Site2.nl will be find with the following URL : http://www.site2.nl/page1/subpage1.aspx. So far so good.
But the content on SubPage 3 will be find with the domain of the first node. In this case http://www.site1.nl/page1/subpage3. That's not how it should be.
In other words, why does Google find SubPage 3 with the domain site1.nl and not with site2.nl?
When you're dealing with multiple sites in the same Umbraco installation you need to make sure that the hostnames have been setup on each node using "manage hostnames". I think that you probably already have done this part.
You also need to go to the umbracoSettings.config file and change the setting <useDomainPrefixes>false</useDomainPrefixes> to true to ensure that url's are unique when running multiple sites.
I should have mentioned above that after the change you should also republish the entire (go to the "Content" node and right click to choose the option).
It might also be neccessary to recycle the app pool. Then it should work :)
Multiple sites and SEO
Site1.nl
- Page 1
-- SubPage1
-- SubPage 2
etc.
Site2.nl
- Page 1
-- SubPage 1
-- SubPage 2
-- SubPage 3
Thanks for your advice.
Hi Rik
Hope this helps.
Tnx Jan. I changed the setting. Do you mean by each node, also each page and subpage or only the rootnode?
Hi Rik
Only your root node.
Hi Jan,
Tnx, I've done that now!
Rik
