How do i force umbraco to redirect from / to /en/home?
the root / is empty and sowing an error.
Might be useful to post a pic of your content structure.
Rich
Master is the entire website root
I'm not sure you need the Master DocType.
If you move your 'en' folder under Content your problem should go away.
it is not working. I get the error:
and the site is not functioning at all, it goes to install page...
Hey,
Sorry, my bad, I didn't see 'Umbraco 5' in the subject title (it's early here).
Though coming from Umbraco 4 I can't see a reason to change the structure for 5.
Are you working from the sample Umbraco 5 site?
hi,
it is not out of example.it is crucial to me to work multilang.
Have you tried "umbracoRedirect"?
if not, you can try and choose data type "content picker".
Found a solution to this? Got the very same problem?
Redirect from home page to /en/home (Umbraco 5)
Rich
Rich
The layout page "Layout.cshtml" could not be found at the following path: "~/Views/Umbraco/Layout.cshtml".
Hey,
Rich
hi,
