  • Pat 56 posts 147 karma points
    Jan 17, 2012 @ 10:43
    Pat
    blog posts pulled through, how to get first few characters
    I have pulled through the latest 2 blog posts using uBlogsy to my homepage, they firstly by default just pull the title of the post in a listed format. How could I get them to :
    A) sit side by side, a few pixels apart  so to differentiate
    B) show the title and the content BUT just say the first 150chars of the content, not all of it
    and C) make it not be green font (it is green i think as the title is a hyperlink
  • Mike Chambers 636 posts 1253 karma points c-trib
    Jan 17, 2012 @ 11:27
    Mike Chambers
    a and c would be alterations to the css and/or html structure of your xslt...
    b can be accomplished in the xslt, with a comination of umbraco.library:stripHtml and substring...
     eg...
    <xsl:variable name="strippedHTML" select="umbraco.library:StripHtml($YOURTITLE)"/>
    <xsl:value-of select="substring($strippedHTML, 1, 150)" />
    Jan 18, 2012 @ 21:25
    Pat
    Thanks for the reply. I am using uBlogsy, and that uses Scriping files (.cshtml), would the same work for that?
    Jan 18, 2012 @ 21:48
    Jeroen Breuer
    In Razor it would look like this:
    using umbraco.MacroEngines.Library;
    @Library.Truncate(Model.rteContent,100)
    //or
    @Library.StripHTML(Model.rteContent)
    Have a look at this blogpost for more examples: http://umbraco.com/follow-us/blog-archive/2011/9/22/umbraco-razor-feature-walkthrough%E2%80%93part-8.aspx
    Jeroen
