  • Dominic Kelly 114 posts 133 karma points
    Jan 17, 2012 @ 18:38
    Dominic Kelly
    SEO tab by default?
    Any way of adding an SEO tab to every data type by default?
  • Rodion Novoselov 694 posts 859 karma points
    Jan 17, 2012 @ 18:59
    Rodion Novoselov
    Hi. You could add it to some additional type and use it as a master type for the rest.
    Jan 17, 2012 @ 19:00
    Tom Fulton
    2
    Hi Dominic,
    You can achieve this by using Master Document Types.  Most people setup a document type called 'Master' that contains the "magic" umbraco properties and an SEO tab with all of their SEO fields. Then you create all your Document Types (Home, Textpage, etc) beneath the Master, and they automatically inherit the tabs & properties from the Master.
    There is a project that has an example template you can start from if you need some guidance:  Master DocType Template
    But, this is really only effective if you plan it ahead of time.  If your doctypes are already created, you can't switch their Master at a later time.  So if you've already created them and don't want to delete & recreate, you would need to add them manually -- or -- you could also use the DocTypeMixins package, which will allow you to create a "mixin" doctype called SEO and easily apply it to any doctypes that need it.
    Hope this helps,
    Tom
    Hi Dominic
    In Umbraco 4 that can be done by creating a document type master where you create the tabs that all of your content nodes have and then you just create document types like "home" and "textpage" etc. with the master as the parent.
    In v5 it's going to be a whole lot more flexible and easy.
    Hope this helps.
    Whoops, I was a little late there :)
    Jan 17, 2012 @ 19:01
    Tom Fulton
    Triple-crosspost!  The more the merrier ;)
    Jan 17, 2012 @ 19:04
    Haha indeed, never experienced a tripple before - great minds think alike! #H5WR ;-)
    Jan 17, 2012 @ 19:19
    Dominic Kelly
    Hmm shame I've already created al my Doc Types...
    How easy is it to access data via a Mixin?
    As simple as?
    <umbraco:Itemfield="seokeyword"runat="server"/>
    Jan 17, 2012 @ 19:20
    Tom Fulton
    Yes, the data access is exactly the same as if the property were added to your doc type.
    Jan 17, 2012 @ 19:22
    Dominic Kelly
    Excellent, I'll give that a try.
    Jan 17, 2012 @ 19:37
    Dominic Kelly
    Hmm can't for the life of me figure this out. I've added the Mixin, created an SEO tab, created the properties, selected all child nodetypes, clicked save. Am I now supposed to see the SEO tab on all other doc types?
    Jan 17, 2012 @ 19:49
    Dominic Kelly
    I'm on Umbraco 4.1.1.1 which is apparently untested.
    Jan 17, 2012 @ 19:54
    Dominic Kelly
    Ok, so I need to create a child mixin... Got it now.
    Jan 17, 2012 @ 20:05
    Dominic Kelly
    Respect to the developer for taking the time to do this plugin, but it's massively buggy. Could have done this manually in half the time!
    Jan 17, 2012 @ 20:08
    Tom Fulton
    Hi Dominic,
    I must admit I haven't used the package much but I'm pretty sure a lot of others use it succesfully.  If you find any bugs you may want to raise them on the DocTypeMixins forums so the developers can fix them.
    And definitely use Master Document Types the next time you have a chance, it will save you a lot of time :)
    -Tom
    Jan 17, 2012 @ 20:20
    Dominic Kelly
    Yup, I'll go with Master Document Types next time around. The biggest problem is once the properties have been copied over, it's not easy to update them from the mixin, so you end up renaming them, then forgetting to add them to tabs (which I think also need to have unique names) and the result are fields all over the place! Nice idea, and probably find if you know the exact process for doing it, but this pretty much sums up my first Umbraco experience - no documentation, extremely unintuative, no polish and .net errors all over the place. I can totally see this CMS is great for developers, but it desperately needs a marketing guy to overhaul the entire experience.
