  • Jan Molbech 31 posts 76 karma points
    Jan 18, 2012 @ 00:02
    Jan Molbech
    problems navigating to next page
    I have created a start page called "Login" with a standard asp:login control. When i log in with the appropriate credentials i want i t to navigate to "home page"
    Above you can see the site structure. When i log in the page does not redirect correctly. the url looks correct but the page still contains the login control and does not contain the correct template. Any idea what I'm doing wrong?
  • Rodion Novoselov 694 posts 859 karma points
    Jan 18, 2012 @ 05:11
    Rodion Novoselov
    Hi. Try to set the "defaultUrl" attribute of the "authentication/forms" element in your web.config file to the Url of your "Home page" (you can get it from the "Properties" tab).
    Jan 18, 2012 @ 06:12
    Jan Molbech
    Is this the part your talking about?
    Jan 18, 2012 @ 06:36
    Jeroen Breuer
    You can also set a property on the asp:login control. Think it's the DestinationPageUrl.
    Jeroen
    Jan 18, 2012 @ 07:50
    Rodion Novoselov
    Yes, from the structure you've presented I can guess that the configuration should look like:
    <forms loginUrl="/" defaultUrl="/home-page/"/>
    or
    <forms loginUrl="/" defaultUrl="/home-page.aspx"/>
    depending on the url style you're using.
    Jan 18, 2012 @ 07:56
    Jan Molbech
    No, that didn't fix the problem.
    Any other suggestions?
    Jan 18, 2012 @ 08:11
    Rodion Novoselov
    Could you tell how the full URL in the browser address bar looks when you come to the login page?
    Jan 18, 2012 @ 08:15
    Jan Molbech
    http://localhost:5253
    and when i have logged in it looks like this
    http://localhost:5253/home-page.aspx.
    I took Jeroen's advise and it worked.
    Thx.
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Jan 18, 2012 @ 10:00
    Michael Latouche
    Hi Jan,
    Can you then maybe mark Jeroen's post as the answer to your question? This will help others that would have the same issue. Thanks!
    Michael.
    Jan 18, 2012 @ 10:06
    Jan Molbech
    I thought i already did that when i clicked the "high five"
    Jan 18, 2012 @ 10:31
    Michael Latouche
    :-) "High Five" is to give karma points to the author of any post you find interesting. Everybody can give "High Five" to anybody except himself, while the "mark as an answer" is only available to the post initiator to indicate which post actually solves the problem.
    Also, "High Five" only works (= give an extra karma point) if you have reached a certain karma yourself (I think 70 but I am not sure).
    Michael.
