  • Mitch 44 posts 159 karma points
    Jan 18, 2012 @ 11:45
    Mitch
    Link to document error
    When publishing a new page in the Content section, the Link to document value is '#'. I've tried republishing all the nodes as per other suggestions but nothing works. Any ideas? Thanks.
  • Rodion Novoselov 694 posts 859 karma points
    Jan 18, 2012 @ 11:48
    Rodion Novoselov
    Hi. Do you mean the link on the content editor "General Properties" tab?
    I remember there used to be a bug with it in some former version.
    Jan 18, 2012 @ 11:56
    Mitch
    Yes, when publishing a page underneath the homepage node and clicking on the properties tab, the Link to document value is '#'. This happens regardless of which template I use.
    Jan 18, 2012 @ 12:06
    Rodion Novoselov
    So, what version do you use?
    I've definitely seen the same issue with top-level documents (besides the very first one) in 4.7.0 until being upgraded to 4.7.1.
    Jan 18, 2012 @ 12:26
    Mitch
    We're using 4.7.0.
    We've just found a workaround by which if we restart the website somehow, it fixes the links. This is obviously not practical going forward so we desperately need a solution. Upgrading may be difficult.
  • Removed User 12 posts 32 karma points
    Apr 18, 2012 @ 03:06
    Removed User
    I'm having the same problem on our live server (works on the other environments). I've restarted the website, but that didn't help unfortunately. Does this mean we have to upgrade to 4.7.1?
  • John Perryn 71 posts 182 karma points
    Jul 24, 2012 @ 16:00
    John Perryn
    This happened to me when I changed the template type for a page
