  • Lee 95 posts 115 karma points
    Jan 24, 2012 @ 01:46
    Lee
    Check for children, then navigate
    I am trying to put together macroe that would basically check whether the current node has any children, if so it will automatically navigate to the first child, if not, it will redirect to the home page.
    Any ideas?
    Many thanks!
  • Rodion Novoselov 694 posts 859 karma points
    Jan 24, 2012 @ 06:38
    Rodion Novoselov
    <msxsl:script language="cs#" implements-prefix="local-script">
      <msxsl:assembly name="System.Web"/>
      <![CDATA[
        public static void Redirect(url As String) {
          System.Web.HttpContext.Current.Response.Redirect(url)
    </msxsl:script>
    <xsl:template match="/">
      <xsl:variable name="firstChild" select="$currentPage/*[@isDoc and string(umbracoNaviHide) != '1' and position() = 1]"
      <xsl:choose>
        <xsl:when test="$firstChild">
            <xsl:value-of select=" local-script:Redirect(umbraco.library:NiceUrl($firstChild/@id))"
         </xsl:when>
        <xsl:otherwise>
            <xsl:value-of select="umbraco.library:Redirect($currentPage/ancestor::*[@isDoc and @level = 1]/@id)"/>
        </xsl:otherwise>
      </xsl:choose>
    </xsl:template>
    You will also have to add a namespace to the <xsl:stylesheet> element: xmlns:local-script="urn:local-script" so that this inline extension works.
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Jan 24, 2012 @ 10:15
    Tim
    I'd recommend moving the redirect function to redirect into an xslt extension rather than having it inline in the XSLT macro. Having code inline like that causes the app to need higher privelidges (so no Medium Trust) and can also causes issue with Macro performance.
    Jan 24, 2012 @ 10:20
    Lee
    Thanks Tim
    Could you possibly give me a bit more info (Sorry I'm new to this!)
    Jan 24, 2012 @ 10:24
    Rodion Novoselov
    Actually I'd better implement it with Razor macro since it would be much short in it.
    Jan 24, 2012 @ 12:18
    Tim
    @Lee, as Rodion says, you can use a Razor Macro, which you can add the redirect function to without any issues, or for creating an XSLT Extension for Umbraco, see the tutorial here: http://blog.percipientstudios.com/2010/11/12/make-an-app_code-xslt-extension-for-umbraco.aspx it shows how Doug switched functions from inline to App_Code for his awesome XSLT Search project. There's another example of writing a compiled extension here: http://en.wikibooks.org/wiki/Umbraco/Create_xslt_exstension_like_umbraco.Library_in_C
    Hope that helps!
    Jan 26, 2012 @ 00:51
    Lee
    No... I'm still lost on this one. Any more advice would be greatly received!
  • Funka! 398 posts 661 karma points
    Jan 26, 2012 @ 03:18
    Funka!
    Hi Lee,
    We are doing something similar in one of our sections. We have a tiny block of code in our master page which I adapted here for you to get started with:
    <%@ Master Language="C#" MasterPageFile="~/masterpages/Master.master" AutoEventWireup="true" %>
    <%@ Import Namespace="umbraco.BusinessLogic" %>
    <%@ Import Namespace="umbraco.cms.businesslogic.web" %>
    <%@ Import Namespace="umbraco.NodeFactory" %>
    <script runat="server">
      void Page_Load(object sender, System.EventArgs e)
        // Based on http://our.umbraco.org/wiki/how-tos/telling-a-page-to-redirect-to-an-external-url
        var currentNode =  umbraco.NodeFactory.Node.GetCurrent();
        if (currentNode.Children.Count > 0)
          Response.Redirect(currentNode.Children[0].Url);
    </script>
    ... Rest of your template here...
    Best of luck!
    Jan 26, 2012 @ 04:14
    Lee
    Can anyone spot anything here:
      var parent = @Model.AncestorOrSelf(2);
      var nodes = parent.Children.Where(parent.NodeTypeAlias == "VacancyRedirect");
      int totalNodes = nodes.Count();
      Response.Write(parent.NodeTypeAlias);
      Response.Write(totalNodes.ToString());
      if (parent != null) {
        if (totalNodes  > 0)
          Response.Redirect(nodes[0].Url);
    I am getting 'problem loading page'. I have a node has a macro container that fires the above code and for some reason it isn't working.
    Although interestingly if I change:
    if (totalNodes  > 0) to if (totalNodes  == 0)
    totalNodes is the number of nodes attached...... it navigates OK!!
    Huh!?
    Jan 26, 2012 @ 10:23
    Tim
    I'd tweak the code slightly, you want to move the null check up a bit, otherwise you could get null reference errors:
        if (totalNodes  > 0)
    Does that work? If not, does it only throw an error on pages with less that 2 ancestors?
