  • Hannes Rahm 28 posts 47 karma points
    Jan 24, 2012 @ 11:10
    Hannes Rahm
    Lower case css class names in Table/Cell properties in Rich Text Editor
    Heyo.
    I try to use my css-defined classes for tables and cells.
    Unfortunately it doesn't work since for some reason the dialogs add them with all lower case letters.
    I could solve this by just using lower case letters but that would be inconsequent with my naming conventions...
    It works perfectly in the main TinyMCE window. The css classes even get properly assigned. But breaks if I look at the page published.
    Any ideas?
    /Hannes
    Jan 24, 2012 @ 11:12
    Hannes Rahm
    Tried to edit my post to add umbraco version, but get an xslt error?
    Anyway: umbraco v 4.7.1.1 (Assembly version: 1.0.4393.24044)
  • awm 187 posts 376 karma points
    Jan 24, 2012 @ 11:24
    awm
    I always thought css classes weren't case sensitive? I think it's generally good practice to make sure all your css classes are lowercase too (although I realise this doesn't help your current predicament!)
  • Fuji Kusaka 2203 posts 4220 karma points
    Jan 24, 2012 @ 11:25
    Fuji Kusaka
    HI Hannes,
    Am not sure......do you want your text to be in UpperCase in your TinyMce??
    //fuji
    Jan 24, 2012 @ 11:26
    awm
    Fuji I think he's written his classes in the editor like this: "MyClass". But when the content's saved and rendered on the front-end, it renders as: "myclass". At least I think that's what the issue is..
    Jan 24, 2012 @ 11:32
    Hannes Rahm
    Css class names are case sensitive in some browsers.
    Example of what happens:
    Left Content (.leftContent) is defined in my css.
    I add it to a table cell and it looks fine in TinyMCE.
    I then save and check the outputted html to find <td style="leftcontent">...</td>
    Which doesn't work in chrome.
    Still looks fine in TinyMCE if I reload.
    Wierd right?
    /Hannes
    Jan 24, 2012 @ 11:39
    Fuji Kusaka
    But in anycase, class is not case-sensitive.
    Left Content  and LeftContent is not the same since you have a space in between for the first class!!
    In the css class you could write something like.
    .LeftContent { font:normal 12px/14px arial;}
    .LeftContent td{ font:normal; text-transform:lowercase;
    //fuji
  • Rodion Novoselov 694 posts 859 karma points
    Jan 24, 2012 @ 12:05
    Rodion Novoselov
    There's something wrong, however - I've checked it for curioucity's sake and found that the value of a "class" attribute inside RTE content is saved, published and rendered as-is - i.e. if I have a class named "TEST" in RTE-associated stylesheet it renders after all exactly as class="TEST", not "test". Could be there any non-default TinyMCE settings that make it to lowercase the class attribute?
  • Mike Chambers 636 posts 1253 karma points c-trib
    Jan 24, 2012 @ 13:01
    Mike Chambers
    could it be that tidyHtml is the culprit here? There is by deafult a second level of html cleaning by default in umbraco... you can turn it off in the /config/UmbracoSettings.config file.
        <!-- clean editor content with use of tidy -->
        <TidyEditorContent>false</TidyEditorContent>
    We use camel casing for class names and they are indeed case sensitive in some browsers when using the xhtml doctype.
    Only difference i can think of from the standard umbraco install that we change that might effect this is the tidyHtml setting.
    Jan 24, 2012 @ 13:14
    Rodion Novoselov
    I have TidyEditorContent = true, so that it's unlikely the reason.
    Jan 24, 2012 @ 13:15
    Mike Chambers
    That means tidy is enabled! try turning off by setting to false? (don't forget to touch the web.config or recycle the app pool to make config settings take effect.)
    Jan 24, 2012 @ 13:38
    Rodion Novoselov
    No, I've tried to set it to false and nothing happens. The class="..." remains as-is without any changes to character cases.
    Hmmm, Hannes, a silly question of mine - haven't you occasionally forgotten to include this TinyMCE-associated CSS file in your template?
    Jan 24, 2012 @ 13:39
    Hannes Rahm
    Turning off tidy doesnt seem to have an effect :/
    I think Tidy happens after saving so, shouldn't really have an effect on this as they are already wrong in TinyMCE before saving.
    I guess it works in the editor since umbraco uses another html declaration...
    The dialog even lists them in lowercase. Guess that says something about it.
    /Hannes
    Jan 24, 2012 @ 13:43
    Hannes Rahm
    Rodion: Sure, I have, occasionaly, but not this time ;)
    /Hannes
    Jan 24, 2012 @ 13:58
    Rodion Novoselov
    OMG, I've expressed myself wrong - of course I meant "accidentally" - not my mother tongue is English :-)
    Jan 24, 2012 @ 14:18
    Rodion Novoselov
     Do you mean this dialog?
    I've just got an idea. Could you look into the dbo.cmsStylesheetProperty table in the database?
    I start to suspect that for some reason you have "stylesheetPropertyAlias" written there in lowercase.
    Jan 24, 2012 @ 14:38
    awm
    I spent a little time looking into this and it looks as though it might be a TinyMCE issue. It seems that other users are experiencing similar effects with other elements:
    http://www.tinymce.com/forum/viewtopic.php?id=26880
    http://www.silverstripe.org/general-questions/show/18516
    I'm just wondering if maybe removing the table plugin will make any difference?
    Jan 24, 2012 @ 15:39
    Hannes Rahm
    The DB reflects the changes correctly.
    Seems like it might be a google chrome + tinymce problem actually.
    I tried a bit firefox and things seemed to work better.
    Anyone else here who use chrome?
    /Hannes
    Jan 24, 2012 @ 15:58
    Rodion Novoselov
    Yep, I use chrome as my working browser but stick to FireFox for development (I find FireBug more convenient for development purposes). I've just tried things in Chrome and everything is still ok - no character case changing all the way.
    Have you tried to track down on what stage class names go lowercased? There're several palced worth to look into:
    1) dbo.cmsPropertyData;
    2) dbo.cmsContentXml;
    3) ~/App_Data/umbraco.config.
