I have an older (4.0.2.1) umbraco site that has a periodic problem where the users suddently can not login to the backend. Restarting the w3svc service seems to solve the problem.
There seems to be a connection to these events being logged on the server:
Process information: Process ID: 4140 Process name: w3wp.exe Account name: NT AUTHORITY\NETWORK SERVICE
Exception information: Exception type: TypeInitializationException Exception message: The type initializer for 'umbraco.BusinessLogic.Actions.Action' threw an exception.
Request information: Request URL: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Request path: /umbraco/umbraco.aspx User host address: 213.173.231.18 User: Is authenticated: False Authentication Type: Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information: Thread ID: 3 Thread account name: NT AUTHORITY\NETWORK SERVICE Is impersonating: False Stack trace: at umbraco.BusinessLogic.Actions.Action.GetJavaScriptFileReferences() at umbraco.cms.presentation._umbraco.RenderActionJS() at umbraco.cms.presentation._umbraco.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Does anybody know what causes this and how to fix it ?
Yes this is logged in the UmbracoLog at the exact ame time:
At /umbraco/umbraco.aspx (Referred by: ): System.TypeInitializationException: The type initializer for 'umbraco.BusinessLogic.Actions.Action' threw an exception. ---> System.NullReferenceException: Object reference not set to an instance of an object. at umbraco.BusinessLogic.Utils.TypeFinder.FindClassesOfType[T](Boolean useSeperateAppDomain) at umbraco.BusinessLogic.Actions.Action.RegisterIActions() at umbraco.BusinessLogic.Actions.Action..cctor() --- End of inner exception stack trace --- at umbraco.BusinessLogic.Actions.Action.GetJavaScriptFileReferences() at umbraco.cms.presentation._umbraco.RenderActionJS() at umbraco.cms.presentation._umbraco.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Sorry for my late reply - did you manage to solve the issue?
I'm afraid I have no clue about what the error could be, but I'm thinking if you have made some kind of customization to the instance recently? In example made a custom user control, xslt extension or something like that?
Problem with backend login
Log Name: Application
Source: ASP.NET 2.0.50727.0
Date: 24-01-2012 12:01:35
Event ID: 1309
Task Category: Web Event
Level: Warning
Keywords: Classic
User: N/A
Computer: xxxxxxx
Description:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 24-01-2012 12:01:35
Event time (UTC): 24-01-2012 11:01:35
Event ID: 1d5ccc9d4ee44b6896ebf1457f0bf1d2
Event sequence: 1280
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-1-129718548513140000
Trust level: Full
Application Virtual Path: /
Application Path: C:\inetpub\wwwroot\
Machine name: xxxxxx
Process ID: 4140
User:
Thread information:
Thread ID: 3
Mikael
Hi Mikael
Does the umbracoLog table contain some entries as well?
Sorry, should have posted that too.
Hi Mikael
