  • Kevin Coster 83 posts 120 karma points
    Jan 25, 2012 @ 14:33
    Kevin Coster
    Two Sites managed by Hostname - umbraco v 4.0.3
    I have a customer who wants microsite setup was planning on doing it as subdomain of main site.
    I have the mainsite setup and for testing purposes have done the following:
    In Umbraco I have set Hostnames on the following sites
    Main site - localhost:8086
    Microsite - localhost:8087
    In IIS7 I have added the following bindings to the site
    Localhost:8086
    Localhost:8087
    But when I browse to to localhost:8087 the mainsite loads up and doesnt load the subsite.
    Have read and amended the umbraco.config as per http://our.umbraco.org/wiki/how-tos/running-multiple-websites-on-one-umbraco-installation
    But it is still doing same thing any pointers to what might be causing this?
    Kev
    Jan 25, 2012 @ 20:08
    Hi Kevin
    Have you recycled the app pool after making the mentioned changes? It should be enough - also double check if the change in the umbracoSettings.config has indeed been saved (I sometimes tend to miss that, embarrisingly enough) :-)
    Jan 26, 2012 @ 23:38
    Kevin Coster
    Thanks Jan
    Found it! Umbraco doesnt like port numbers being used! whether thats unique to 4.0.3 I havent tested yet.
    localhost:8086
    localhost:8087
    Just reverted to one site setup
    give meaningful site names in hostname in umbraco and all worked fine
    mysite.com
    sub.mysite.com
    Bug maybe?
