Weird bug/problem.
I have media folders (verified that these have images in them) in my media folder as seen below:
However, my Media Section is empty:
These images are working and are used throughout my site.
The problem is I can no longer select them from media section, nor can I select them using various media pickers...
Permissions seem fine, pretty stumped!
Any help would be much appreciated!
Owen
How did you add the folder to you media folder? Media in Umbraco isn't just folders. It's also data in the database. Have a look in the umbracoNode table to see if you can find your images in there.
Jeroen
Hi Jeroen,
I added the images using the Rich Text Editor - Insert Image control.
Looking into the DB now. Thanks
Media Section empty - Have images in /media
Weird bug/problem.
Owen
Jeroen
Hi Jeroen,
Owen
