  • Eugene 17 posts 38 karma points
    Feb 01, 2012 @ 16:59
    Eugene
    Sorting and YouTube Pop-up Issues
    We have a slider on the homepage that consists of several images. When I re-sort the slides in the medias section, the first slide (#0) is actually shown as the second slide when you preview and/or publish. I've tried re-storting several times but no luck. In the past re-sorting several times would eventually work. Any idea what's going on?
    My second question has to do with one of the slides. The developer created a section in which we could embed YouTube code, so that when someone clicks on the slide, the YouTube video pops-up. However, in preview and publish mode, nothing happens! Any idea why? It worked for a second, but then stopped. Any idea?
    Thanks in advance. BTW, I'm not technical if you can't notice :)
    Feb 01, 2012 @ 17:13
    Feb 01, 2012 @ 17:59
    Eugene
    I only undersoon about 10% of those posts. That said, I deleted old versions of the slides from the trash bin, but still did not work. BTW, the sort issue is specifically for this one slide that I want to show up first... Plus the video doesn't pop-up.
