  • Sophie Mitchell 23 posts 43 karma points
    Feb 02, 2012 @ 17:27
    Sophie Mitchell
    How do I create/add a drop down menu?
    Hello - please could someone point me to a video or code so that I can implement a drop down menu on my Umbraco site.
    Thank you
  • Rodion Novoselov 694 posts 859 karma points
    Feb 02, 2012 @ 17:42
    Rodion Novoselov
    Hi. If I understand your question right then Implementing drop-down menu has nothing to do with Umbraco itself - you just render it as regular HTML and then apply to it any drop down menu technics (javascript or CSS) that you like - you can google lots of those.
    Feb 03, 2012 @ 12:14
    Sophie Mitchell
    Thanks Rodion - so is there no way to get this working from the normal sub navigation in umbraco?
    Feb 03, 2012 @ 12:19
    Rodion Novoselov
    Why not? In a regular site you usually draw somthing like <ul> in your html and then apply some CSS or JS to it to turn it to a drop-down menu. Here's the same with the only difference that you're rendering your <ul> with an umbraco macro.
    Feb 03, 2012 @ 12:40
    Sophie Mitchell
    Ok yep I could create the menu using <ul><li> etc but how do I render that using an umbraco macro? Sorry I'm very new to Umbraco and the old cms I used would generate the drop down automatically.
    Thank you
    Feb 03, 2012 @ 15:07
    Feb 03, 2012 @ 15:46
    Sophie Mitchell
    Thanks - I've watched the video and I see how the navigation works. But, it just displays the level one items. How do I make it display the 2nd level as well? Thanks, Sophie
    Feb 03, 2012 @ 16:05
    Rodion Novoselov
    You can create your Xslt macro from the template which you can use as a start point and modify as you like:
    Feb 03, 2012 @ 16:21
    Sophie Mitchell
    Maybe I wasn't clear. I've got a working menu in place. It displays only the top level items all working no problem.
    Through my lack of knowledge with umbraco/xslt etc I don't understand what changes I need to implement to get the 2nd level navigation to display in the menu as well. I'd ideally like it in a dropdown. If you could guide me on that I should be able to control the dropdown with css. Are you able to be more explicit with how I achieve this? Here's the xslt code I have:
    <!DOCTYPE xsl:stylesheet [
        <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
        <!-- Input the documenttype you want here -->
        <xsl:variable name="level" select="1" />
        <xsl:template match="/">
     <ul id="topNavigation">
           <li class="home">
             <xsl:if test="$currentPage/@id = $currentPage/ancestor-or-self::* [@level=$level]/@id">
                 <xsl:attribute name="class">home current</xsl:attribute>
             </xsl:if>
             <a href="/">Home</a>
           </li>
         <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
      <li>
         <xsl:if test="@id = $currentPage/@id">
            <xsl:attribute name="class">current</xsl:attribute>
          </xsl:if>
        <a class="navigation" href="{umbraco.library:NiceUrl(@id)}">
          <span><xsl:value-of select="@nodeName"/></span>
        </a>
      </li>
    </xsl:for-each>
    </ul>
        </xsl:template>
    </xsl:stylesheet>
    Thanks for your patience
