  • Cleyton 7 posts 27 karma points
    Feb 07, 2012 @ 21:21
    Cleyton
    Problem saving richtext data with images
    I'm using the latest version of Umbraco (4.7.1.1 binaries) and I have problems with images.
    On editing, I put an image and the src of <img> tag is:
    src="/media/3273/kokaynerydomingosbattisti_edferreiraae_07022012_288x212.jpg"
    After save, the SRC changes to:
    src="/media/3273/kokaynerydomingosbattisti_edferreiraae_07022012.jpg" :
    It's a bug?
    Feb 08, 2012 @ 06:49
    Jeroen Breuer
    If you add an image in the RTE it can get resized (if you select that during insert or part of the default settings on the datatype), but it should stay that way. Now somehow it shows the original image instead of the resized one. Did you have this problem with other versions of Umbraco as well?
    Jeroen
    Feb 08, 2012 @ 12:21
    Cleyton
    Hello Jeroen,
    I have not used the old versions...
    There is any process with the image filename?
