  • alexei 21 posts 40 karma points
    Jul 11, 2009 @ 15:39
    alexei
    robots.txt for multisite configuration
    Hi! We have several sites and domens under one Umbraco installation. They have single wwwroot directory, so we can't create a robots.txt file for each site. May be you have any suggestions except one file for all sites?
    Jul 11, 2009 @ 16:33
    Morten Bock
    2
    Well, you could look into letting asp.net handle the robots.txt request, and the use urlrewriting to serve the appropriate content for the current domain. You could even do it using umbraco to edit the content for each domain.
    Let me know if this doesn't make any sense, and I'll try and explain a bit better.
    Jul 11, 2009 @ 16:54
    alexei
    I've tried it with urlRewriting tool but failed to get rules for different domains. Could you give me an advice how to do this if I have 3 variants of site naming: http://maindomain.com http://subsite.maindomain.com and http://secondDomain.com
    thanks
    Jul 11, 2009 @ 17:18
    Morten Bock
    You could do something like this:
    <add name="robotsrewrite"
        virtualUrl="(.*)://(.*)/robots.txt"
        rewriteUrlParameter="ExcludeFromClientQueryString"
        destinationUrl="~/robots.aspx?domain=$2"
        ignoreCase="true" />
    Then you could make a robots.aspx page in umbraco that uses the querystring parameter to serve different content.
    The url would be like: /robots.aspx?domain=maindomain.com
    Now all you need to do is to tell IIS to send the .txt request through the aspnet_isapi handler so it actually hits the urlrewriting mechanism.
    Jul 11, 2009 @ 17:30
    alexei
    thanks a lot I'll try it
