  • Eray 11 posts 31 karma points
    Feb 23, 2012 @ 11:01
    Eray
    Umbraco 5 login expried box shows up on backoffice
    i've installed Umbraco v5 on hosting and i login into backoffice. My user's role is
    Administrator. I can see all sections. But when i click developer section or creating
    first Document Types (set a name then click next). Login Expired Box shows up.
    so i have to login with credentials. Box disappears and nothing happens.
    then i click again same process start again.
  • Martin Larsen 1 post 21 karma points
    Mar 11, 2012 @ 17:54
    Martin Larsen
    I have the smae issue. Any luck cracking it?
    Mar 12, 2012 @ 09:47
    Eray
    i didnt find solution yet :(
  • Will 2 posts 22 karma points
    Mar 16, 2012 @ 13:09
    Will
    Anyone find a solution to this? First time I have ever used umbraco and falling at first hurdle! :)
    Mar 16, 2012 @ 13:30
    Will
    Ah, if you are running under IIS make sure Iuser / App pool user has write permissions. This fixed it for me.
