  • Vishal Joshi 5 posts 25 karma points
    Feb 24, 2012 @ 09:32
    Vishal Joshi
    ModelMetadataProvider Issue
    I am new to Umbraco. I am implementing the checkboxList control in our project. I am getting following error sporadically
    Server Error in '/Umbraco5RTMWork' Application.
    An instance of ModelMetadataProvider was found in the resolver as well as a custom registered provider in ModelMetadataProviders.Current. Please set only one or the other.
    Exception Details: System.InvalidOperationException: An instance of ModelMetadataProvider was found in the resolver as well as a custom registered provider in ModelMetadataProviders.Current. Please set only one or the other.
    Source Error:
    Stack Trace:
    [InvalidOperationException: An instance of ModelMetadataProvider was found in the resolver as well as a custom registered provider in ModelMetadataProviders.Current. Please set only one or the other.]
       System.Web.Mvc.SingleServiceResolver`1.get_Current() +369
       System.Web.Mvc.ModelMetadataProviders.get_CurrentInternal() +24
       System.Web.Mvc.ControllerActionInvoker.GetParameterValue(ControllerContext controllerContext, ParameterDescriptor parameterDescriptor) +303
       System.Web.Mvc.ControllerActionInvoker.GetParameterValues(ControllerContext controllerContext, ActionDescriptor actionDescriptor) +153
       System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +825600
       System.Web.Mvc.Controller.ExecuteCore() +159
       System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +335
       System.Web.Mvc.<>c__DisplayClassb.<BeginProcessRequest>b__5() +62
       System.Web.Mvc.Async.<>c__DisplayClass1.<MakeVoidDelegate>b__0() +20
       System.Web.Mvc.<>c__DisplayClasse.<EndProcessRequest>b__d() +54
       System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +469
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +375
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
    When I comment the @Html.CheckboxListFor line, page gets reneder.
    I wrote one custom class that extends
    DefaultModelBinder
     from using System.Web.Mvc
     namespace
    later on I register this in Global.asax.cs file as
     ModelBinders.Binders.DefaultBinder = new DefaultGraphModelBinder();
    I am not getting the selected items from the checkboxlist control after POST in controller. I guess model binding is the problem
    Can any one please help.
    Thanks in anticipation
