  • Rik Hodiamont 56 posts 156 karma points
    Feb 24, 2012 @ 11:55
    Rik Hodiamont
    Document type empty after adding a media picker
    I have a problem with the media picker. I can't figure out why, I add the media picker like hundred times, but this time it won't work.
    This are my document settings:
    When I open the document in de content editor, i got empty tabs:
    When I change all the media pickers to textstrings, it works. But when I change one type to Media Picker, it will be empty in the content section.
    I tried to recycle the application pool, I stopped en started the site in IIS, but that won't do the trick.
    I use Umbraco 4.7.1.1.
    Has anyone an idea?
    Thanks in advance.
    Feb 24, 2012 @ 13:32
    Jeroen Breuer
    Seems like there is a javascript error. Do you see any errors in the console of your developer tools? You could also try to use DAMP and see if you still have this problem.
    Jeroen
    Mar 02, 2012 @ 10:32
    Rik Hodiamont
    Thnx Jeroen.
    I found something else. I changed the Alias name to userCalltoaction, so without - and that worked.
    Rik
