  • Mike 81 posts 101 karma points
    Feb 27, 2012 @ 19:01
    Mike
    info under settings > structure tab and other tabs missing
    A select few document types will not show any info under the structure tab, generic tab, or the tabs tab.
    The only thing I have done was install the uComponents package and create a datatype. I did not notice if it was an issue prior.. I tried all browsers to make sure it was not a display issue.
    Feb 27, 2012 @ 19:20
    Hi Mike
    What happens if you try to reset the permissions for network service and iusr? These issues are usually related to permissions being altered somehow I think.
    Feb 27, 2012 @ 19:24
    Mike
    I am not sure what I need to do.
    Is this a system wide issue on my server or under the specific acct within the umbraco? I checked another site and I am not having the same issues.
    Feb 27, 2012 @ 19:26
    Hi Mike
    Try setting the permissions on the root folder containing Umbraco and make sure it's inherited all the way down to all files and folders on the sublevels.
    Feb 27, 2012 @ 19:33
    Mike
    That did it!!! I gave IUSR full permissions on the root folder!
