  • WebsterJ 5 posts 25 karma points
    Feb 27, 2012 @ 23:17
    WebsterJ
    Add Macro In Single Document
    I'm primary a front end guy, and I have a Macro that has been create for me that generates a webform.
    There is a main contact page and this page is the only one that needs to have this macro added to the main body content area.
    Seems like having a "macro field" property would be an easy way to do this.
    Is there a way to add a macro to a single document or do I need to create a seperate template for this?
    Thanks.
  • Lee Kelleher 4026 posts 15836 karma points MVP 13x admin c-trib
    Feb 28, 2012 @ 09:43
    Lee Kelleher
    Hi WebsterJ,
    If you are using the rich-text editor for you content, you can insert a macro directly into it.  (In the editor, there is a little orange icon - top-right-ish).
    This would remove the need for having a separate template just to render the macro.
    Cheers, Lee.
    Feb 29, 2012 @ 21:43
    WebsterJ
    Ahhh.  gotcha.  thanks a bunch.
