  • Pete Wilson 11 posts 31 karma points
    Feb 29, 2012 @ 13:36
    Pete Wilson
    System.OverflowException: Value was either too large or too small for an Int32.
    An odd one, I getted the dreaded
    error when saving the following xslt, and am completely puzzled as to why. Can any see anything wrong with my code?
    I can skip testing box, but it's bugging what might be causing it.
    Thanks all
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
        xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:yorkshire.library="urn:yorkshire.library"
        exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets yorkshire.library ">
    <xsl:template match="/">
    <!-- start writing XSLT -->
           <xsl:for-each select="$currentPage/node[@nodeName='pods']/node[@nodeTypeAlias='Pod']">
            <xsl:variable name="title" select="data [@alias = 'title']" />
            <div class="podContainerIndustry">
                <div class="podTitleIndustry"><h3><a href="{umbraco.library:NiceUrl(data[@alias='podLink'])}" class="podTitleLinkIndustry" title="{$title}"><xsl:value-of select="data [@alias = 'title']" disable-output-escaping="yes" /></a></h3></div>
                <div class="podImageIndustry">
                    <a href="{umbraco.library:NiceUrl(data[@alias='podLink'])}"><img src="{umbraco.library:GetMedia(data[@alias='podImage'], 'false')/data}" alt="{$title}" /></a>
                <div class="podIndustryCopy"><p><xsl:value-of select="data [@alias = 'podText']" disable-output-escaping="yes" /></p></div>
                <div class="podIndustryLink"><a href="{umbraco.library:NiceUrl(data[@alias='podLink'])}" title="Read more about {$title}"><img src="/images/industry/IndustryReadMoreBtn.png" alt="Read more about {$title}" /></a></div>
           </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
    Feb 29, 2012 @ 13:43
    Tom Fulton
    Hi Pete,
    The error is caused because when you save the XSLT, Umbraco does a "test run" on it, and it may not have values to supply to NiceUrl and GetMedia which both require integers, so if they run without a value it will cause the error above.  You can get around it by checking the "Ignore errors" checkbox, or you can add some code to ensure these calls only run when they have values, ie:
    <xsl:if test="data [@alias='podLink] &gt; 0">
    </xsl:if>
    <xsl:if test="data [@alias='podText'] &gt; 0">
    </xsl:if>
    ...etc
    HTH,
    Tom
    Feb 29, 2012 @ 14:05
    Pete Wilson
    Excellent, that worked! many thanks Tom, much appreciated.
    Pete
