  • manwood 87 posts 109 karma points
    Mar 01, 2012 @ 14:55
    manwood
    How do I define the items to appear in a Radiobox?
    I'm sure that when you define the field under 'Document Types' and you select Radiobox, I used to get the option of defining the list of items to appear in the list. I can no loonger see this. Am I mistaken, are lists defined somewhere else?
    I'm running version 4.7 and using Google Chrome.
    Any ideas?
    Mar 01, 2012 @ 15:00
    Tom Fulton
    You can control the "prevalues" (options) under the Data Type itself, so under Developer -> Datatypes -> Radiobox.  There you can manage which options will show up.  It's probably a good idea to create a new instance of the datatype and name it what it will be used for rather than the generic "Radiobox", ie "Radiobox - Alignment".
    HTH,
    Tom
