  • Hardy Wang 91 posts 112 karma points
    Mar 05, 2012 @ 18:29
    Hardy Wang
    Persist Empty Tag in TinyMCE
    By default TinyMCE will remove all empty Html tags, how can I configure it to allow empty tags?
    Mar 05, 2012 @ 20:32
    Hi Hardy
    I'm not sure how it can be done but I'm a bit curious to learn why you want this to happen?
  • David Verberckmoes 46 posts 77 karma points
    Mar 15, 2012 @ 15:23
    David Verberckmoes
    Hi Hardy,
    you can edit the tinyMceConfig.config file in the config folder.
    Look for the <validElements> element and remove the minus sign("-") before any of the tags you dont want to get stripped out in the editor. Make sure you recycle your app pool or touch the web.config in order to reload the config.
    Rgds,
    David
