I pasted iFrame code via the HTML view in the rich text editor. It shows up in the design view.
However, when I go back to the HTML view everything is gone. When I go to the website, the iframe is not showing up. Is there a setting I need to allow this to work right?
I tried to edit my forum post. However I am getting an xslt error. So I will just append it...
However, when I save and publish then I go back to the HTML view everything is gone. When I go to the website, the iframe is not showing up. Is there a setting I need to allow this to work right?
I am using the standard iFrame code to embed a google map.
I checked out the link and I added it to the config. However it's still not working. Any thoughts why? Seems like it should. I even did a iis reset to make sure it wasn't somehow not reading the new xml doc
tidy is a second level of cleansing on the html... we've been running 100+ sites with it turned off with and haven't seen any issues ;-)
I wonder if it's a legacy feature from when tinymce implementations didn't do such a good job of cleansing? or actually pre tinymce when the richtext editor used a wysiwyg other than tinymce?
Hey MarkD, I implemented your solution. There seems to be a major issue happening when it comes to the iframe. It seems to somehow create massive havic.
Anything past the closing iframe tag is ignored. Viewing the source, it all looks correct. Also my jquery menu bombs, the script is called at the end of the main template thus, it's definitly the iframe macro keeping any of the HTML to be rendered.
I prefer to render elements like iFrames (e.g. for youTube embeds) as macros. i.e. you could create a macro that renders the iFrame in a macro. If the src is dynamic it can be passed as a parameter to the macro. This also negates the need for your content editors to know anything about iFrames.
Probably moving away from the post main thread now... but I find using macros in the richcontent area a bit hit and misss... first you have to explain the "aw snap" issues with Chrome to the client, then you sometimes end up with random <p></p> tags before and/or after the rendered macro content at the front end.
If the macros are utilised in templates then all seems fine... it is just macros in the RTE that exhibit strange goings on.
Hey Mike Chambers, I implemented your solution and I am getting the same results where the iframe code is somehow stopping the rendering of any further HTML.
Bottom line, the version of TinyMCE/Tidy that ships with Umbraco 4.7 is broken by not allowing iframes even though they are allowed in the TinyMCE config. Tidy should not be stripping out the empty iframe tag. And, TinyMCE should not be removing content inside the iframe tag, which is your no frames content.
iFrame not showing up in rich text editor
Thanks for the assistance.
Mike
Mike
http://our.umbraco.org/forum/using/ui-questions/25452-TinyMCE-manipulates-my-html-tags
Think this answer is what you are looking for...
Hey Mike,
I found this as well. Jan can you tell me why it is not recommended to do the below? Also any other work arounds?
Is there a way to make a page and use it as a macro?
From Jan
In order to get this to work you will need to set tidy to false in the umbracoSettings.config though, which is not neccesarily recommended to do.
Have anybody found a solution to it?
Are you experiencing any of these issues?
Cheers
Paul
Hi Paul,
MarkD submitted the following code. However there were issues.
@Paul - Was the below the same as you were referring to?
@Mike - Can you elaborate a bit more on your solution?
1) Create a New Clean XSLT File and tick Create Macro.
2) Give the Macro a Name, such as: Vimeo IFrame Embedd for Vimeo Universal Player
3) Paste in the following Code:
Part B: Add Paramaters to the Macro
1) Save your XSLT file.
2) Go to the Macro Section and in the new macro add the following 3 paramaters, all of which are of Type text:
Alias and Name:
3) Save the Macro
Part C: Using the Macro to Embedd the Vimeo Video on the Umbraco Page1) Go to the umbraco content page you want to embedd the iframe video on to.
2) Click on the Macro button and select the new macro from the drop down.
3) For the location, paste in the URL of the Video. Such as: http://player.vimeo.com/video/40514689 (Which you get from your IFrame Code)
5) Enter your required width and height.
6) Save and Publish your page. You will need to log out of Vimeo to test this or the Vimeo page will open instead of the video.
Anyone have any thoughts?
Figured it out!!!!
Add some text before the ending iframe tag. This forces the tag to render.
changing the xsl:output method to HTML probably would have worked as well
Thanks Paul! That did work as well.
Hi Mike and Paul,
That is great. This works for me.
Mark
FYI, another method to stop self closing of divs in xslt macros...
{iframe}{xsl:value-of select="normalize-space('')"/}{/iframe}
