  • Profiterole 232 posts 264 karma points
    Mar 06, 2012 @ 16:17
    Profiterole
    Questions for Examine
    Hi guys,
    I'm using XSLTSearch on 4.7.1.1 and I need a stronger search engine. Naturally, I looked at Examine. Here's some considerations before my questions :
    a) I know XSLT but not razor.
    b) I'm using Umbraco "as it is", I don't do visual studio programming stuff.
    Now, the questions :
    1) If use the xslt version(http://our.umbraco.org/wiki/reference/xslt/using-examine-in-xslt) of examine, will I be able to use examine/lucene boost parameter? This is for me the main idea for using examine. I could boost a field more than another.
    2) If the answer to question 1) is "no", will I be able with razor script?
    3) Can I use boost and fuzzle on the same field?
    Thank you for your patience!
