  • Christian Sparre 55 posts 20 karma points
    Jul 16, 2009 @ 10:26
    Christian Sparre
    Problem using Media library and media picker
    Hi, I have a problem with the media library. Uploaded images does not have the correct URL when selected from the Media Picker in the Rich Text editor.
    If I create a new image called "Image01" and uploads a picture that is named "Image01_resized.jpg" it displays fine in the Media Library but when inserted on a page the url is set at /media/{id}/Image01.jpg. The physical file is still called Image01_resized.jpg.
    How do I correct this?
    I'm running: umbraco v 4.0.2.1 (Assembly version: 1.0.3441.17657) on Windows 2008
    Hope someone can help me :)
    Christian
    Jul 16, 2009 @ 11:27
    Morten Bock
    Is this a general problem, or only when using underscores?
    What happens if you create a media node "myimage" and upload a file "myuploadedimage.jpg" or "myuploadedimage_subtitle.jpg".
    Jul 16, 2009 @ 13:39
    Christian Sparre
    Hey
    You are spot on!, this only seem to happen when the uploaded file's name contains underscore(s). For now I'll remove any underscores, but the end-users won't nessesarily know why and how to do that.
    Can anyone else reproduce this or is it just my deployment that does this?
    Christian
    Jul 16, 2009 @ 14:57
    Dirk De Grave
    Have seen other posts on this as well, don't know whether thas was still on the old ugly forum tho... If it's reproducable, I'd suggest to add a work item in Codeplex (but check first if it hasn't been reported before)
    TIA,
    /Dirk
