verticalscroll bar not seen fully when choosing a media type
Hello Friends,
i am using the latest version of umbraco (4).
I was developing the site when i found that in content part when i was inserting a new picture , by selecting the insert picture option from toolbar and then selecting the Create new option from the tabs and then click on choose for media type save at - a pop up opens but i am unable to scroll down fully to see all the links in it.....
Can anyone suggest me whether it is a bug in umbraco of i need to do some changes in some files....
Attaching herewith the screenshot for your reference
It's looks like a bug in umbraco. I checked on a few different browsers and still the same issue. I noticed if you open a few folders the scrollbar shows up but still partially half-way. I appears the iframe inside the dialog is too tall.
It would be great if you could post the bug on codeplex, and encourage people to vote it up :)
Hello Friends,
Thanks in Advance
Regards
Vikas Mehta
-Chris
Sure Chris....i will post to codeples just now. Thanks for the suggestion
