    Jul 16, 2009 @ 14:29
    Sebastiaan Janssen
    Why are dates in Dutch format?
    When I use:
    umbraco.library:LongDate($currentPage/@updateDate)
    The date is nicely formatted and shows the day name. I had not seen anything odd on my site, but I just got a comment on my blog letting me know that the date format was Dutch, which is absolutely correct.
    I just don't know why, can anybody explain? I can fix it just fine, I just want to know where the language is coming from so I can keep it in mind for the future.
    Thanks!
    Jul 16, 2009 @ 14:33
    Morten Bock
    101
    A guess would be that if you haven't set any language/hostnamse inside umbraco, it will use the locale from the servers settings. I've even experienced that it used the language settings from the useraccount running the application pool.
  • Ron Brouwer 273 posts 768 karma points
    Jul 16, 2009 @ 14:35
    Ron Brouwer
    Hi Sebastiaan,
    The date is formatted using the current culture i suppose
    http://msdn.microsoft.com/en-us/library/system.globalization.cultureinfo.currentculture.aspx
    Or do you mean something else?
    Ron
    Jul 16, 2009 @ 14:42
    Sebastiaan Janssen
    Thanks Morten, excellent stuff, that helped and I didn't have to change the date format :-)
    Ron: Yup, that's exactly what it was doing, just didn't know it was doing this by default in LongDate. But it does make sense, Umbraco cannot determine what else should be used of course.
    Jul 16, 2009 @ 14:50
    Ron Brouwer
    You can specify the default using the following:
    <configuration>
       <system.web>
          <globalization
               culture="en-US"
               uiCulture="de-DE"
       </system.web>
    </configuration>
  • Jay Walker 10 posts 38 karma points
    Aug 24, 2009 @ 21:07
    Jay Walker
    Ron,
    In which config file would you place the default globalization values?
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Aug 24, 2009 @ 21:10
    Peter Dijksterhuis
    Jay,
    you should edit the web.config for that.
    Note there is allready a globalization-tag, just add culture and uiUlture to it.
    HTH,
    Peter
