  • Sophie Mitchell 23 posts 43 karma points
    Mar 14, 2012 @ 19:15
    Sophie Mitchell
    Simple Editor not working correctly
    I am using the simple editor to display web page summaries.
    When I use the bold, italics or the link functionality I see the html added to the summary. However, the html is also displaying on the website.
    For example I make some text bold and I see this in the simple editor <strong>test</strong>. Rather than becoming bold in the summary on the actual web page I see exactly the same <strong>test</srtong>.
    It seems like something's not set up correctly - any ideas?
    Mar 14, 2012 @ 19:32
    Tom Fulton
    How are you outputting the value of the simple editor, with an XSLT macro?  If so, you need to add disable-output-escaping="yes" to get the HTML to render, ie:
    <xsl:value-ofselect="yourField"disable-output-escaping="yes"/>
    This goes for RTE and any other fields that store HTML also.
    Or if you're using Razor I think it's @Html.Raw(Model.yourField)
    HTH,
    Tom
    Mar 14, 2012 @ 19:40
    Sophie Mitchell
    Hi Tom - I'm using an xslt macro - that fix worked. Thank you!
