At the moment I have a field set up in my master template for this but I dont want to be adding titles manually for every node. I still want to keep this field incase I want to manually override the titles.
I was thinking could I create different doc types for this under a content structure called SEO. Might look like this.
SEO (Content Folder) -- Page Titles -- Meta Descriptions -- Meta Keywords
Not sure if this is the best way or how to then apply these to the correct nodes.
I would suggest that you have the above properties on each document type that represents a page on your website. And then you could create a seo fallback tab on your "home" (root node) to use when the seo fields have not been filled in on one or more of the child nodes.
I will also recommend that you make some generic fallback for the page title where you take the nodename and concat it with the fallback title value to make sure each page has a unique page title value in case it has not been filled out.
We've often found that if you give Jan's sort of setup to the client that they very rarely undestand the if you don't put anything in then it will default to x + y... So we extend slightly on Jan's approach, and use the parameters as he has, but hook into the page creation event to automatically put the default into the seo page title.
public class SetDefaultsHandler : ApplicationBase
public SetDefaultsHandler()
Document.New += new Document.NewEventHandler(Document_New);
void Document_New(Document sender, umbraco.cms.businesslogic.NewEventArgs e)
Document doc = (Document)sender;
try
doc.getProperty("menubarTitle").Value = doc.Text + UmbracoJPT.Utils.Util.GetPropertyValueRecursive(doc, "seoAppend");
doc.getProperty("altTitle").Value = doc.Text;
doc.getProperty("title").Value = doc.Text;
//System.Web.HttpContext.Current.Response.Write(doc.ContentType.Alias);
switch (doc.ContentType.Alias)
case "NewsDocument":
doc.getProperty("hideInNavigation").Value = true;
break;
case "FileDocument":
break;
case "MemberDocument":
break;
default:
break;
catch { }
//Log.Add(LogTypes.Custom, doc.Id, "Document_AfterNew Executed in AutoUnpublishNewsHandler");
We also have a dashboard to do search and replace type updates across all pages for if the SEO title changes at some point in the project.
I have set up an SEO tab on my content types which is all working fine.
How do I get it to use the Home node as the fallback title? I can set it to use a different field such as @pagename, but I dont see a different node option?
Efficient way of adding Page Titles
What would be the best way to add Page Titles?
-- Page Titles
-- Meta Keywords
Any ideas?
Robert
Hi Robert
I hope this helps.
public class SetDefaultsHandler : ApplicationBase { public SetDefaultsHandler() { Document.New += new Document.NewEventHandler(Document_New); } void Document_New(Document sender, umbraco.cms.businesslogic.NewEventArgs e) { Document doc = (Document)sender; try { doc.getProperty("menubarTitle").Value = doc.Text + UmbracoJPT.Utils.Util.GetPropertyValueRecursive(doc, "seoAppend"); doc.getProperty("altTitle").Value = doc.Text; doc.getProperty("title").Value = doc.Text; //System.Web.HttpContext.Current.Response.Write(doc.ContentType.Alias); switch (doc.ContentType.Alias) { case "NewsDocument": doc.getProperty("hideInNavigation").Value = true; break; case "FileDocument": doc.getProperty("hideInNavigation").Value = true; break; case "MemberDocument": doc.getProperty("hideInNavigation").Value = true; break; default: break; } } catch { } //Log.Add(LogTypes.Custom, doc.Id, "Document_AfterNew Executed in AutoUnpublishNewsHandler"); }We also have a dashboard to do search and replace type updates across all pages for if the SEO title changes at some point in the project.
Robert
