  • Hardy Wang 91 posts 112 karma points
    Mar 22, 2012 @ 16:54
    Hardy Wang
    Error happened to load a page
    I captured following error messages from one of my page. The message does not tell very clearly what is the problem.
    Any idea how shall I debug?
    request handler current url '/root-node-1/sub-node-2.aspx'
    umbracoRequestHandler xpath: '/root/*/* [@urlName = "root-node-1"]/* [@urlName = "sub-node-2"] | /root/* [@urlName = "sub-node-2"]'
    umbracoRequestHandler Just before xPath query (False, '/root/*/* [@urlName = "root-node-1"]/* [@urlName = "sub-node-2"] | /root/* [@urlName = "sub-node-2"]')
    umbracoRequestHandler pageXPathQueryStart: '/root'
    umbracoRequestHandler Adding to cache... ('/root-node-1/sub-node-2.aspx')
    umbracoRequestHandler After xPath query
    umbracoRequestHandler Access checking started
    umbracoRequestHandler Page protected
    Unhandled Execution Error
      at umbraco.cms.businesslogic.web.Access.HasAccces(Int32 documentId, Object memberId)
      at umbraco.requestHandler..ctor(XmlDocument umbracoContent, String url)
      at umbraco.UmbracoDefault.Page_PreInit(Object sender, EventArgs e)
      at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
      at System.EventHandler.Invoke(Object sender, EventArgs e)
      at System.Web.UI.Page.PerformPreInit()
      at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    Mar 22, 2012 @ 17:10
    Hardy Wang
    Update 1, after I deleted all nodes in recycle bin I started to get error node id not found. Somehow Umbraco links it to a node in recylce bin and I have deleted already.
    [ArgumentException: No node exists with id '1825']
       umbraco.cms.businesslogic.CMSNode.setupNode() +323
       umbraco.cms.businesslogic.web.Access.HasAccces(Int32 documentId, Object memberId) +44
       umbraco.requestHandler..ctor(XmlDocument umbracoContent, String url) +4097
       umbraco.UmbracoDefault.Page_PreInit(Object sender, EventArgs e) +1294
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +25
       System.EventHandler.Invoke(Object sender, EventArgs e) +0
       System.Web.UI.Page.PerformPreInit() +49
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1716
    Mar 22, 2012 @ 17:22
    Hardy Wang
    Update 2: I opned umbraco.config and found that node id 1825 there. I ran query select * from dbo.umbracoNode where id = 1825 and there is no such record in database. I manually deleted the node from umbraco.config, clicked the parent node and publish everything again. I opened umbraco.config and saw 1825 appeared again!!
    I really have no clue now, why the node does not exist in DB and after published it still showed up?
  • Grant Thomas 291 posts 324 karma points
    Mar 22, 2012 @ 17:25
    Grant Thomas
    Please state the version of your Umbraco instance.
    Mar 22, 2012 @ 18:07
    Hardy Wang
    Sorry, forget to mention it is 4.7.1.1
    The Xml section
          <Template1 id="1825" parentID="1822" level="3" writerID="6" creatorID="6" nodeType="1393" template="1394" sortOrder="3" createDate="2012-03-22T11:15:02" updateDate="2012-03-22T10:16:43" nodeName="Sub Node Name" urlName="sub-node-2" writerName="Hardy Wang" creatorName="Hardy Wang" path="-1,1396,1822,1825" isDoc="">
            <pageTitle>Sub Node Name</pageTitle>
            <umbracoRedirect />
            <topBanner />
            <contentBodyText><![CDATA[<?UMBRACO_MACRO param1="11111"
    param2="222222" macroAlias="MyMacro" />]]></contentBodyText>
          </Template1>
          <Template2 id="1830" parentID="1822" level="3" writerID="6" creatorID="6" nodeType="1826" template="1827" sortOrder="3" createDate="2012-03-22T11:07:37" updateDate="2012-03-22T11:23:52" nodeName="Sub Node Name" urlName="sub-node-2" writerName="Hardy Wang" creatorName="Hardy Wang" path="-1,1396,1822,1830" isDoc="">
            <umbracoRedirect />
            <topBanner />
          </Template2>
    Mar 22, 2012 @ 18:13
    Hardy Wang
    I created a node with wrong template, I deleted it (node id = 1825) and created a new one with correct template (node id = 1830). So you can see other than template anything else is identical. But 1825 just won't go away.
