    Mar 24, 2012 @ 12:55
    Anthony Candaele
    setting values for uComponents TextString Array
    Hi Guys,
    For a membertype property I am using the uComponents TextString Array data type. This property holds jobs selected by a member like this:
    jobid   job title
    Now I need to set this programmaticaly from my selectjob.ascx user control.
    I tried to do this like this:
    string selectedjobs = jobId.ToString() + "," + jobFunctionTitle;
    jobseeker.selectedjobs = selectedjobs;
    However, when I test this, I get an YSOD in the member for that member:
    the error is: System.ArgumentException: Invalid JSON primitive: test job
    Does anyone know how to set a membertype property of datatype uComponents TextString Array programmaticaly?
    Your help is much appreciated,
    Anthony
    Mar 24, 2012 @ 13:11
    Lee Kelleher
    2
    Hi Anthony,
    The underlying format for the data (as in stored in Umbraco's database) is as aJavaScript serialized List<string[]>, (or a multi-dimensional array of strings).
    The format you'd need to take is...
    "[ ['id1', 'title1'], ['id2', 'title2'] ... ]";
    Or build up a List<string[]> object and serialize it using the JavaScriptSerializer methods?
    Cheers, Lee.
    Mar 24, 2012 @ 13:38
    Anthony Candaele
    Perfect:
    Thanks a lot Lee, you saved my (Satur)day. Now I can enjoy the beautifull weather and have a beer :)
    greetings,
    Anthony
    Ghent (Belgium)
    Mar 24, 2012 @ 14:15
    Anthony Candaele
    Hi Lee,
    The beer will have to wait a little longer. When I test this and selected a second job, the first selected job in the uComponent TextString Array data type gets overwritten:
    I configured the data type like this:
    I there something wrong with this configuration?
    greetings,
    Anthony
    Mar 24, 2012 @ 14:22
    Lee Kelleher
    Hi Anthony,
    Concerned to why the images next to the textboxes aren't displaying?
    I'll give it a quick test here... see if I run into the same problem.
    Cheers, Lee.
    PS. I'm sure the beer will taste so much better once this is working! ;-)
    Mar 24, 2012 @ 14:27
    Lee Kelleher
    Quick one... which version of uComponents are you using?
    Anthony Candaele
    ok, thanks for looking into this. My version of Umbraco is 4.7.1
    Mar 24, 2012 @ 14:29
    Anthony Candaele
    oops, posts have crossed, my version of uComponents is 3.0.1
    Mar 24, 2012 @ 14:34
    Lee Kelleher
    Thanks!
    OK, the broken images are a bug.  I wrongly assumed the paths were relative... doh! ;-)
    Still looking into the set the value.
    Mar 24, 2012 @ 14:43
    Anthony Candaele
    Ok, my code looks like this:
    //Add selected job to member_selected_job property of jobseeker membertype
                string selectedjobs = "[ ['" + jobId.ToString() +"', '" + jobFunctionTitle + "']]";
                jobseeker = (MemberProfile)HttpContext.Current.Profile;
                jobseeker.SelectedJobs = selectedjobs;
    Mar 24, 2012 @ 14:48
    Lee Kelleher
    Just checking, are you wanting to overwrite the existing data/value, or append to it?
    Mar 24, 2012 @ 14:55
    Lee Kelleher
    Hi Anthony,
    If you want to append a value to the array, try using the serializer.  Might seem a little overkill, but will work...
    var member = new umbraco.cms.businesslogic.member.Member(1172);
    if (member != null)
        var property = member.getProperty("test");
        if (property != null && property.Value != null)
            var serializer = new System.Web.Script.Serialization.JavaScriptSerializer();
            var value = property.Value.ToString();
            var array = serializer.Deserialize<List<string[]>>(value);
            // add the items to the array
            array.Add(new string[] { jobId.ToString(), jobFunctionTitle });
            // write back to the property
            property.Value = serializer.Serialize(array);
            member.Save();
    Cheers, Lee.
    Mar 24, 2012 @ 16:05
    Anthony Candaele
    Hi Lee,
    Thanks for the code. I hade to tweek it a little because I couldn't acces the Id property of the member:
                var member = Member.GetCurrentMember();
                if (member != null)
                    var property = member.getProperty("member_selected_jobs");
                        jobseeker.SelectedJobs = serializer.Serialize(array);
    But now it works fine:
    Mar 24, 2012 @ 16:09
    Lee Kelleher
    Cool! Now enjoy that beer!
    Also I've fixed the broken images - but that wont be out until next bug-fix release (v3.0.4)  (unless you want to compile the library yourself?)
    Cheers, Lee.
    Mar 24, 2012 @ 16:22
    Anthony Candaele
    Hi Lee,
    I'm glad I could help - a little bit - at  locating this broken images bug. I think I just wait 'till version v3.0.4 of uComponents.
    thanks a lot for your help and have a nice weekend,
    Anthony
  • bob baty-barr 1180 posts 1294 karma points MVP
    Sep 19, 2012 @ 23:26
    bob baty-barr
    This looks great, i am using it to store page favorites for members, but for some reason i have a blank one first, then it fills in?
    pretty much using the exact code above...
    what am i doing wrong?
    Sep 20, 2012 @ 15:42
    bob baty-barr
    hey, i think i got this working fairly well... not sure about the blank one still... need more testing...
    however, how would i check for a duplicate and not add if it already exists - for example i am adding page ids and titles.
    string myValue = currentNode.Id.ToString();
    i am assuming i would wrap this section:
    array.Add(new string[] { myValue, nodename });
    but not sure what my check would be - remember, i am a hack ;)
    Sep 21, 2012 @ 15:34
    bob baty-barr
    okay, so i have tried to change this process to just saving the page id into a multiple textstring datatype... however, i am running into an issue of how to append that list? using the same methodology gives me int to generic list error. any thoughts?
