check your umbracoSettings.config file (in config folder). Look for the line:
<TidyCharEncoding>UTF8</TidyCharEncoding>
It should be UTF8 there, if not, make the change, save the file. Just to make sure, open the web.config, add a space somewhere and save it. (to force an application restart)
Now, if you edit a page, the weird characters should not come back.
I am facing problem of � character in Rich text editor
Hi All,
I am new in umbraco. I am using Rich Text Editor as a property. When I press "Enter" key I am getting '�' character on screen.
can anybody help me?
Thanks in advance
Darpan
HTH,
Peter
Wasn't this solved in 4.0.2.1?
Yes
Thanks Peter. It Works
Hi peter please mention that the solution is courtesy by jack (Jigar).. Just kidding mate...
